Q
How does CloudOS handle high availability and prevent failures from taking down services?
2025-11-24Ask Question
  • 0Following
  • 0Collection,1217Browse
Problem Description:
Network and Network Description:
CloudOS uses several strategies for high availability:
  • For Virtual Machines (VMs): It uses "HA Clusters." If a physical server fails, the VMs running on it are automatically restarted on another healthy server in the same cluster.
  • For Applications: A feature called "Application HA" can monitor specific applications/services inside a VM. If the application crashes, it can automatically restart it.
  • For Infrastructure: The distributed architecture (Regions and AZs) allows for cross-data center disaster recovery. If one entire site has a problem, services can failover to another site.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
