Q
UIS3000 G6 Cluster initialization
2025-12-03Ask Question
  • 0Following
  • 0Collection,1470Browse
Problem Description:
If we start three hosts as a cluster, Then can we shut down one host one by one, add new nodes step by step (PDU shorage), and finally complete the entire cluster initialization?
Network and Network Description:
No, because joining OSD requires a heartbeat connection. Without it, peering will persist indefinitely. If more than half go offline, it will directly cause the cluster to fail.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
