Q
Vlan Tag question
2025-12-09Ask Question
  • 0Following
  • 0Collection,1408Browse
Problem Description:
After creating a VLAN, is it possible to send tagged packets not only within the virtual infrastructure but also to physical servers outside it?
Network and Network Description:
Yes, it is possible to send tagged VLAN packets between the virtual infrastructure and external physical servers after creating a VLAN. The key requirement is to ensure end-to-end consistency of VLAN tagging configuration across the entire network path.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
