Q
the CloudOS Agile Edition solution and the CloudOS Lite Edition software
2026-03-10Ask Question
  • 0Following
  • 0Collection,1050Browse
Problem Description:
What is the difference between the CloudOS Agile Edition solution and the CloudOS Lite Edition software
Network and Network Description:
In materials related to the CloudOS solution, there are the Standard Edition, Lightweight Edition, and Agile Edition. In materials related to the introduction of the CloudOS software, there are the Standard Edition and Lite Edition. Could you explain the differences between them?
  These are concepts from two dimensions: "deployment solution" and "product form", which differ in different contexts.
1. Deployment solution dimension: Refers to the differences in networking and delivery levels, including standard version solutions, lightweight version solutions, and agile version solutions. It refers to specific deliverable solutions formed based on CloudOS software, combined with different network architectures (SDN/VLAN), hardware configurations, and integration levels. This is the "external performance" and implementation form.
2. Product form dimension: Refers to the capability set of the CloudOS software itself, including the standard version and the Lite version. It refers to the upper limits of the CloudOS software's own function set, management scale, and technical architecture. This is the definition of the software's "internal capabilities".
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
