Q
Where can I obtain the technical specifications of CloudOS 7.0?
2026-03-20Ask Question
  • 0Following
  • 0Collection,1034Browse
Problem Description:
Network and Network Description:
You can obtain the technical white paper for CloudOS 7.0 through internal channels, which contains clear technical indicators that can be communicated externally, such as the maximum number of Regions a cloud platform can support, the maximum number of CPU cores a single virtual machine can support, and other information.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
