Q
Why does the platform-layer disaster recovery of CloudOS 7.0 refer to UCO disaster recovery?
2026-03-20Ask Question
  • 0Following
  • 0Collection,1024Browse
Problem Description:
Network and Network Description:
1. UCO serves as the brain of operation and maintenance, and only the brain needs to run across Regions. UCA and UCS are components deployed locally within each Region/AZ. Their reliability is ensured through cluster mode, enabling them to withstand node-level or AZ-level failures.
2. For the deployment requirements of UCO disaster recovery, please refer to the solution configuration guide.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
