Q
What should be noted for storage selection in the CloudOS 7.0 project?
2026-03-20Ask Question
  • 0Following
  • 0Collection,1040Browse
Problem Description:
Network and Network Description:
1. Prioritize storage models and software system versions explicitly supported in the compatibility list.
2. Models not included in the compatibility list require adaptation promotion. Adaptation methods include: full management and monitoring (requiring in-depth development), docking only through the cinder plug-in (requiring a small amount of development), and only mounting LUNs (no development required).
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
