Q
Why are Geneve encapsulations used for host overlay tunnels?
2026-03-20Ask Question
  • 0Following
  • 0Collection,1053Browse
Problem Description:
Network and Network Description:
The Geneve header is extensible (consisting of an 8-byte fixed header plus 0 to 252 bytes of variable TLV), enabling the tunnel to carry rich information such as logical datapath fields, input/output ports, conntrack zones, and more. OVN (Open Virtual Network) constructs virtual networks using logical routers and logical switches. For cross-Hypervisor (CVK) communication, such additional metadata is required to achieve precise forwarding and control logic for distributed gateways.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
