Q
How is the raw capacity of distributed storage calculated?
2026-03-21Ask Question
  • 0Following
  • 0Collection,1373Browse
Problem Description:
Network and Network Description:
It is necessary to consider the difference between the nominal and actual capacity of disks (approximately 8%), available capacity requirements, and data redundancy strategies (replication or erasure coding). For example, if 300TB of available capacity is required and three replicas are adopted, the raw capacity demand is approximately 1177TB.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
