Q
What is version control for object storage?
2026-03-21Ask Question
  • 0Following
  • 0Collection,1465Browse
Problem Description:
Network and Network Description:
Retain version records for uploaded objects. After versioning is enabled, multiple files with the same name can exist in object storage, which are sorted by version according to the upload time sequence without overwriting each other.
 The versioning feature allows multiple versions of objects to be retained in object storage, enabling quick restoration to historical versions and data recovery in the event of application failures or other unexpected situations.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
