Q
Is VM-level backup possible when using block storage?
2026-04-20Ask Question
  • 0Following
  • 0Collection,995Browse
Problem Description:
In the "Back up VMs" section of the help file, it states: "For VMs that use block devices as disks or use raw disks, online backup, incremental backup, and differential backup are not supported." I would like to clarify if this means VM-level backups are restricted in this configuration.
Network and Network Description:
It's block device not block storage,RAW not support,it means BLOCK DEVICE.
Block Device: A block device is also called a raw device, which does not have a file system, for example, a storage LUN on an IP SAN or FC SAN.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
