Q
Is the Standard License sufficient for backing up to a remote site?
2026-04-20Ask Question
  • 0Following
  • 0Collection,1196Browse
Problem Description:
I assume there are no licensing issues for this, but I would like to verify.
Network and Network Description:
Yes, Standard is ok.
In addition, I'd recommend using the CB7000 (AnyBackup) backup solution, which is our preferred choice.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
