Q
How to reinstall a virtual machine via CloudOS7.0
2026-06-15Ask Question
  • 0Following
  • 0Collection,728Browse
Problem Description:
Network and Network Description:
  CloudOS provides the function to rebuild virtual machines, eliminating the need for users to manually mount ISO files to reinstall the system. During the system reinstallation of an instance, a new instance will be created. Once the system reinstallation is completed successfully, the old instance will be deleted.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
