Q
What entrances are available for users to quickly search resource instances?
2026-06-19Ask Question
  • 0Following
  • 0Collection,488Browse
Problem Description:
Network and Network Description:
1. My Resources Page (Primary Entrance)
Entrance Location: After logging into the user console, select the [Resources/My Resources] menu item in the upper right corner of the interface to access the My Resources page.
Search Methods: In the filter box above the resource list, you may filter or query resources by project name and instance ID. Filtering and viewing by product type (such as cloud servers, cloud disks, etc.) and nodes is also supported.
2. Global Search Box (Console Navigation Bar)
Entrance Location: A search box (usually marked with a magnifying glass icon) is located on the top navigation bar of the user console page.
Search Methods: It supports searching products and services by keywords, enabling quick jumps to the corresponding cloud service list pages.
3. Project Management Page (For Project-Level Resource Search)
Entrance Location: Select [Resources/Project Management], enter a specific project, then click <View Resources>.
Search Methods: On the project resource management page, you can filter resources by selecting products and nodes, or enter the instance name of a resource in the search box to locate a specified instance.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
