Q
Why must bare-metal services strictly comply with compatibility requirements?
2026-06-19Ask Question
  • 0Following
  • 0Collection,484Browse
Problem Description:
Network and Network Description:
Bare-metal service enables in-depth management and control over physical hardware. Every procedure, ranging from power consumption management to operating system installation, involves close interaction with underlying hardware. The compatibility list serves as a "technical whitelist" that guarantees the cloud platform can control such physical hardware correctly, reliably and efficiently. For models not included in the list, their underlying interaction links remain unvalidated, and forced deployment will trigger unpredictable issues or malfunctions.
Edit Answer
You are editing the answer
If you want to comment on the question or other answers, please use the comment function.
Dear user, please log in to perform this operation!
Confirm
